NilObjectException
Posted: Wed 24. Dec 2014, 18:50
Found in 5.3.7, reproduced in 5.3.10.
I entered "W1AW'3" (without the double quotes) in the call sign field for a QSO. (Note the single quote instead of a slant.) The QSO is in the log, but whenever I try to select that line to correct the error, RUMlog gets "An exception of class NilObjectException was not handled. The Application must shutdown."
Just as a note, I have found problems uploading QSOs to LotW with leading and/or trailing spaces.
73 and thanks for all your good work, Bill AE6JV
