Can't connect to DXCC.res and UCSDB database
w6ub
Unread post by w6ub »
Using RUMlog 5.3.5 with Mavericks:
When starting RUMlog the follow errors are posted: Can't connect to DXCC.res and Can't connect to UCSDB database.
Several RUMlog features seem to be working well, such as the cluster and ADIF log imports. I have RUMlog and RUMlog-5.3.5 folder in 'Applications' and DXCC.res along with my log.rds in 'Documents'. I have enabled RUMlog to open these items but that didn't help. Where should I locate the various components?
Do I need to remove RUMlog and reinstall?
Larry W6UB
Re: Can't connect to DXCC.res and UCSDB database
After downloading just unzip the downloaded file and move the complete folder to a location where ever you want. Do not move files out of the folder.
w6ub
"After downloading just unzip the downloaded file and move the complete folder to a location where ever you want. Do not move files out of the folder."
Tom, I think this is what I did initially. Once the unzipped file is in the Applications folder, then what? Click and open RUMlog main file from within the folder? Some startup instructions would be helpful.
Can I recover from where I'm at now or do I delete everything and start over?
Larry
Just move all files back into the RUMlog folder. Your logbook files can be located outside. In the folder is a User's Manual provided. Please start to read the chapters "Installation" and "Quick Start".
