Dropbox issue?
Posted: Thu 12. Sep 2013, 20:16
by iz0tws
(before my best thanks for a so complete logger and ipad app, it is perfect for my needs).
Now an issue related to the dropbox sync, or at least it seems to be related to dropbox.
If I save a qso from Mac all the qso are in the rsd file and I can see all qso in Ipad.
Instead if I add some qso from Ipad the rsd file is not update.
Dropbox log tell me that file has been updated, but inside there are no new qso.
Re: Dropbox issue?
Posted: Thu 12. Sep 2013, 20:34
The system is not designed to work with both devices parallel. RUMlog on the Mac doesn't notice changes in the log. After syncing you can press Command W and the new logged QSOs should become visible.
Re: Dropbox issue?
Posted: Sat 14. Sep 2013, 09:11
by iz0tws
No, the 2 program are not working in parallel.
The issue is related to the fact that the new qso recorded in rumlog2go are not written in the dropboxfile. The file is updated (i can see it in the dropbox status) but no new qso is written there.
Re: Dropbox issue?
Posted: Sat 14. Sep 2013, 15:08
by w8hap
Try shutting the iPad down completely and bringing it back up. Then try the dropbox transfer. The only way I can transfer ADIF files is using this approach. Otherwise, the mailed ADIF file contains "0" QSOs.
Re: Dropbox issue?
Posted: Sat 14. Sep 2013, 17:01
by iz0tws
I also tryed to uninstall an reinstall again but with the same result.
If can be helpful in the issue analysis is the following fact.
Let's say the log in the dropbox shared file contains 2 QSO.
Both the two QSO are written by RUMlog (mac).
As soon Ipad sync with dropbox rumlog2go (ipad) shows the 2 QSO.
Now if I add a third QSO in the Ipad and save it, I can see the spinner appearing and the dropbox file is updated.
If I open with the text editor I only see the first two QSo but not the third one.
Also if I export the data from the ipad using export to clipboard only the first two QSO are exported and not the third one.
If I select only the third one and export it, the content of the clipbord is only the ADIF header (<adif_ver:5>........ <eoh> )
If I switch in log settings menu and select a local rsd file and after i switch again on the dropbox file in the IPAD i can olny see the first 2 QSO and the third one is vanished.
So what I think is that the procedure you use for updating the dropbox file, for such a reason, doesn't works correctly. Somthing is written (a null value?) because the file is updated and also dropbox reacts sharing a new version. Maybe some file permission issue?
Re: Dropbox issue?
Posted: Sat 14. Sep 2013, 17:43
Do you use the latest RUMlog version 1.1.1?
I just came back from a trip, I will check the issues next week.
Re: Dropbox issue?
Posted: Sat 14. Sep 2013, 19:01
by iz0tws
yes 1.1.1
I made another trial. I created the log from the IPAD and now it seems everything works. So my hypothesis is that if I create the log file from mac some issue related to permission raise up.
