Kenwood TS-480
VA3BRW
Kenwood TS-480
Unread post by VA3BRW »
After seeing a note in the cocoaModem board, I moved to try RUMped, but without success after much…
Despite all my attempts, RUMped seems not to 'see' my radio.
My hardware is a MacPro (LION) into a microKeyer II connecting to my Kenwood TS-480. Normally, I use MacLoggerDX, but would like to try RUMped, especially for the upcoming field day. So the base question is, should I be able to have RUMped interact with my TS-480? If so, can you identify the area where I have most likely misconfigured my setup? Thanks,
73 Brian
Re: Kenwood TS-480
In the RUMped preferences under the General tab make sure you have set all options you want to use with your MKII.
The TS-570 setting should work with your TS-480. Other users may confirm that.
N1JM
Re: Kenwood TS-480
Unread post by N1JM »
570 works for the 480.
John N1JM
