Newby: K3, MicroKeyer II, cM and PSK config.
Posted: Thu 23. Jun 2011, 18:47
by k6osx
Hello All,
Going into my first FD as the RTTY/PSK operator and want to use my Macbook Pro (10.5.8). No real working experience with digital modes, just an occasional contact here and there. Using the good info in the "Feeling like an Idiot..." thread I seem to have been able to get RTTY working via FSK-D. Now I would like to configure PSK as an available operating mode.
RTTY via FSK was pretty straight forward. Not sure which data mode I should use for PSK on the K3 (AFSK, Data A or PSK-D). Since I'm a newby and this is a big learning experience (i.e. contesting, using RUMPed, RTYY & PSK), I'd like to make it simple to minimize "operator error" as much as possible. To be honest, not sure if I should being RUMPed instead of RUMLog given my minimal logging/contesting experience.
I'm a little fuzzy on what to configure in cM and RUMped for the PSK mode. Any advice/help would be greatly appreciated. Thanks in advance.
Vy 73 de k6osx,
Darin
Re: Newby: K3, MicroKeyer II, cM and PSK config.
Posted: Thu 23. Jun 2011, 21:59
For PSK you should use the Data A mode. Configure cM in the same way as you would do, when you use cM as a stand alone program.
Posted: Thu 23. Jun 2011, 23:04
by k6osx
Thanks. Do I need to worry about audio routing, will default settings for both cM and RUMped be ok?
Posted: Fri 24. Jun 2011, 06:52
Well, pending on your hardware configuration you have to set at least the audio input and output (PSK only, not FSK) device.
