IC-7000 CAT Problem
Posted: Tue 11. Jan 2011, 10:40
Hallo,
I need your help
I have a IC-7000 and I have a CAT Problem.
I'm trying to install the CAT system for Mixw or HRD. With HRD nothing is running I can't link the TRX with HRD and with Mixw I just can control the IC-7000 in one sense only (PC to TRX) . When I put my mouse on the CAT bar of MIXW and change the frequency, the IC-7000 can adjust the frequ but When I'm turning the knob of the TRX, the CAT bar of mixw don’t follow and the frequ of MIXW is not more the same
With HRD nothing is running.
I’m using a cable USB with USB-Serial driver converter with Prolific Driver
With your Program RUM7Kcontrol I can’t connect the IC7000 and can’t use your software. Why ?????
Can you help me ?
73 de Paul, ON6DP
I need your help
Can you help me ?
73 de Paul, ON6DP
