API
Posted: Fri 16. Feb 2024, 14:59
by EI2KK
Hi
Is there any API (UDP?) I could use to send/change frequency and set value to callsign field?
Re: API
Posted: Fri 16. Feb 2024, 16:02
You can use:
  • Apple Script - see Function Library
  • UDP in the Flex Radio export format (N1MM Import)
  • UDP in the N1MM export format
Re: API
Posted: Fri 16. Feb 2024, 19:09
by EI2KK
Thank you
