Cmd Macros and Elecraft KX2
Posted: Wed 27. Dec 2023, 18:29
Hi Thomas,
I am using your RUMlog app on an iPad and with an Elecraft KX2 transceiver connected via Bluetooth.
Manually everything works correctly, I can change the frequency, mode, etc.
What I find impossible to configure are the "Cmd Macros1 to 10" macros.
I give a name to the Cmd Macro1 button and in the box to include the command sequence I place any command supported by the KX2, for example change frequency and mode FA00007020000;MD3; I then press the "Done" button and in the window next to the selection of bands and modes the button with the name that I have entered appears correctly, but when I press it it does nothing. If I go back to "edit settings", the macro1 that I had already programmed appears blank, it only keeps the button text. How do I have to be able to program these macros and be able to control the KX2? Isn't there a manual that explains all this? I have searched the forum and I have not found anything, nor in the manual on your website (/docs/en), the truth is I cannot find any documentation on this topic.
Thank you for your help and work.
EC2AQW
EC2AQW
