Automatic logging to QRZ?
Posted: Fri 11. Aug 2023, 15:36
by g6phf
I'm new to RunlogNG and to logging programs in general.
I notice some people seem to be able to upload their logs almost in real time with qrz.com ?
Is this possible with Rumlog?
Or is there an interim step?
I have eQSL, LoTW, QRZ all setup in Runlog but I must admit I am not sure on how or if they interact between themselves.
The only way I have found to get the logs to QRZ is export from Rumlog and then upload to QRZ.
Is there a better way?
Otherwise its a great program and thanks for develop[ing it!
Mike
Re: Automatic logging to QRZ?
Posted: Fri 11. Aug 2023, 16:11
RUMlog can't upload direct to qrz.com, you need an utility:
https://apps.apple.com/de/app/qso-uploa ... 3292?mt=12
Posted: Fri 11. Aug 2023, 16:33
by g6phf
Thank you!
I actually found an older post after I submitted this one, so apologies for not searching better!
It looks like you had a change of heart since that last time and created a separate utility, which is good
Mike
Posted: Sat 12. Aug 2023, 08:40
by g6phf
Ok, this is working well.
One possible enhancement would be to have an option to not upload a certain field? For example the comment field.
Sometimes it's nice to keep this more private.
Mike
Posted: Sun 13. Aug 2023, 11:31
by g6phf
Is there any obvious reason why the logging might have stopped from QSO Uploader? This seemed to stop yesterday morning, Saturday sometime.
I've restarted both RUMlogNG and the QSO uploader but still not working.
Mike
Posted: Sun 13. Aug 2023, 11:36
The Upload utility gives you a lot of status information. You should share this.
Posted: Mon 14. Aug 2023, 07:48
by g6phf
I believe it was my doing. I found through a process of elimination that the following boxes need to be ticked in RUMlogNG
Is that correct?
Mike
Posted: Mon 14. Aug 2023, 09:00
See the documentation in the Upload Utility! You have to set the address and the port, do not use the default address! Enable only one set of settings, not both for the same function!
Posted: Tue 15. Aug 2023, 17:10
by g6phf
Tom, with those settings I can send log data to 2 programs?
IS that correct?
Posted: Tue 15. Aug 2023, 21:40
You can send log data to two different broadcast addresses. One in your local network can serve multiple applications on multiple devices.
The second one was introduced to send log data to an external server in the www, for example qsomap.org.
