"?" appears in Band column | Bug?
Posted: Wed 5. Aug 2020, 05:32
by photogonal@gmail.com
When I save a QSO, it appears the program is not translating the frequency to a band entry value. Instead, it inserts a "?" in Band column.
Any ideas how to fix this?
Rob
Re: "?" appears in Band column | Bug?
Posted: Wed 5. Aug 2020, 08:53
A ?? indicates an out of band condition, the frequency is outside of your specified band edges.
Posted: Thu 6. Aug 2020, 04:51
7253 Khz was not specified by me to be an out of band condition. How might I change the default?
Posted: Thu 6. Aug 2020, 09:17
Preferences-->QRGs
You should see and read carefully Menu-->Help for the fundamentals.
Posted: Thu 6. Aug 2020, 18:11
I entered preferences, QRGs, and changed the 40m band edge to 7300. I then re-entered the frequency in the QSO, then saved QSO, which lead to the removal of the "?". All fixed!
I had previously searched the menu for help but could not find a solution. Thanks for your help! I gather the default band edge for 40m applies for some countries. 7300 is the band edge for Canada.
Thanks again!
Rob
