You can enable or disable the flow controls, it's up to you. But you have to match the settings in your trx! You can't have flow control and control lines for PTT or CW at the same time.
That't why we have a lot of options, you can set it up for your needs. There isn't the one correct setting.
Microham USB III not showing the list of CAT serial ports
Re: Microham USB III not showing the list of CAT serial ports
I searched and read further on the topic in order to figure it out. it is clear now and I managed to match my rig settings and baud rates.
Dankeschön
Dankeschön
