TS-890S
N1JM
TS-890S
Unread post by N1JM »
Any thought to adding the TS-890S to RumLogNG and controlling some of its features?
73, John N1JM
iz6fxs
Re: TS-890S
Unread post by iz6fxs »
I've found that TS-590SG works... Who knows what we're missing. CW Keyer seems to work too.
If you select the TS-990 something about "split" messes up the correct communication between RUMlogNG and the radio.
iz6fxs
Re: TS-890S
Found what's seems to be missing: while using the DXLab suite server for the WSJT to command the radio the data mode is not being set... Nothing major but...
