LoTW incoming 1 QSO(s) corrected
Posted: Sat 8. Sep 2018, 12:20
by va3cp
I am using RUMlogNG 3.12.2 and have seen two or three instances when downloading data from LoTW, a QSL that is red. At the bottom of the LoTW incoming window, it says "1 QSO(s) corrected"
When I log into LoTW, I can see that my QSL is matched. My RUMlogNG log entry is the same as the matched QSL on LoTW.
What could have been wrong with my LoTW upload that this log entry needed to be corrected?
Re: LoTW incoming 1 QSO(s) corrected
Posted: Sat 8. Sep 2018, 13:31
This message means, that your logged DXCC entity doesn't match the DXCC entity in the QSL record. Your QSO record DXCC entity was changed to the DXCC according the LoTW QSL. See the middle paragraph concerning Use QSL details: http://dl2rum.de/RUMlogNG/docs/en/pages/LoTW_Prefs.html
BTW, the color should be yellow or orange. Red entries mark QSL records which were not found in your logbook.
Posted: Sat 8. Sep 2018, 14:18
by va3cp
Thanks Tom,
Yes, the text is actually orange when I look at it again.
I did a dummy entry into RUMlog for GW0DSJ and it comes up as GW, Wales, EU. The corrected DXCC for this call sign from LoTW is G, England, EU.
I looked at the June 2018 ARRL list of DXCC's http://www.arrl.org/files/file/DXCC/201 ... ted(2).txt and it lists GW as Wales DXCC entity 294. I have an MW0 confirmed through LoTW as Wales even though MW is not in the above list. Very strange, seems like a glitch in the LoTW database for GW entries. Anyway, looks like you have it right in RUMlog.
Regards...
Posted: Sat 8. Sep 2018, 14:33
My only explanation is, GW0DSJ made it wrong while applying for the LoTW certificate and the ARRL didn't x-checked it carefully. According qrz.com he is located in Wales.
You should send him an e-mail and ask for clarification.
Posted: Sat 8. Sep 2018, 14:34
by va3cp
Will do that.
Cheers..
