Problem with LoTW
k8trc
Problem with LoTW
Unread post by k8trc »
I'm able to push and pull QSLs from eQSL and push new QSLs to LoTW but every time I select LoTW in I get:
Error downloading data
and I'm presented with the LoTW website login page. My call and password are set correctly and logging in within this window does nothing.
Re: Problem with LoTW
This web page is for your information only when something was going wrong. An interaction is not possible! Scroll through the window to find an error message.
A screen shoot would be helpful.
k8trc
Error is Username/Password incorrect. However, I can use the same username/password to login via a web browser.
Some special characters may cause problems Make sure you use only characters and numbers in your password.
k8trc
That was the problem. It is working now.
