rumlogng and gpredict (pull VFO status from rigctld)
Posted: Mon 26. Feb 2018, 19:21
Hi Thomas,
I use gpredict for satellite comms, it controls the rig via rigctld network interface. Is there any way the RUMlogNG pulls the current VFO status (frequency) from the rig via the same network interface (localhost:4532 by default)? If I set TX1: Interface TCP, CAT TCP: HOST 127.0.0.1, PORT 4532, the rigctld says only
Command '' not found!
and RUMlogNG is not able to pull the current VFO frequency...
Thanks a lot.
73, Pavol OM0AYY
Thanks a lot.
73, Pavol OM0AYY
