Very easy to set up and get up and running. Congratulations!
I do have a feature request. I would very much like to log the azimuth and distance to each contact in the user defined fields.
Right now, it looks like one must manually enter the these values from the clublog info pane into the user defined fields.
It would be great if RUMLogNG could be set up to do this automatically. I realize that this may be a difficult task. I know of only one other log that can do this -- XLog. But XLog is very basic and does not nearly have all the capability that RumLogNG has!
In the meantime, please consider adding the following ADIF fields in the Preferences so I can map them to my User Defined Fields:
- DISTANCE
ANT-AZ
MY_RIG
RIG
TIME_OFF
I routinely log My_RIG info and the RIG info of the other station. I would like that info to be preserved when the log is exported into ADIF format.
Many thanks,
Rob
