support for microHAM USB II
Control and memory management software for Icom transceivers
Unread postby w6dlf » Mon 26. Nov 2007, 20:10
I am unable to control my 7000 using RUMtrol7K through my microHAM USB PC interace. Regardless of RUMtrol settings the SQL (squelch) is set as soon at the program initiates. Is anyone using microHAM USB successfully with RUMtrol and if so, what are your settings?
Many thanks,
Dave
w6dlf
w6dlf
Re: support for microHAM USB II
Unread postby DL2RUM » Mon 26. Nov 2007, 20:20
Using a microHAM interface on a Macintosh is not supported yet. The microHAM is not just an interface, special drivers are needed.
Maybe it works under Windows, I have no info yet.
Unread postby w6dlf » Sun 2. Dec 2007, 22:03
Actually I'm using it with Windows XP. Yes it takes drivers because it is creating virtual COMM ports for access via USB
microHAM might loan you one for testing.
Dave
w6dlf
Unread postby DL2RUM » Sun 2. Dec 2007, 23:18
Hi Dave,
I have a loan interface here, but the problem is I have no Windows computer here to test. :cry:
Try first to deselect all checkboxes in the preference window. When this does not help, connect only the control cable to the TRX and power the interface from an external source.
Return to RUMtrol
Who is online
Users browsing this forum: No registered users and 0 guests
