List of supported contests
NN7M
Unread post by NN7M »
Thank you for adding the Washington Salmon Run.
Ryan.
PA9CW
Unread post by PA9CW »
First of all, thanks for all the effort for your apps. Vy nice job.
I'm using RUMlogNG since more than ten years now. Since a short time I have no Windows computer. So also no more N1MM for contesting.
I see a lot of supported contests for RUMlogNG, but not for those two:
- Wednesday mini-contest. http://ua9qcq.com/en/contestinfo.php?la ... &Year=2015
- Memorial OK1WC (MWC) Activity. http://www.memorial-ok1wc.cz/index.php?page=rules2l#HF
Can you make these or is it possible to make your own contest, just like in N1MM ?
PE2V
Unread post by PE2V »
Great logging app for Mac OS!
Is it possible to add the "Friese Elfstedencontest"? If you like I can translate the rules for you!
In Dutch (description): http://www.pi4lwd.nl/11stindex.htm
In Dutch (rules): http://www.pi4lwd.nl/11st2019reg.htm
Thanks! Vy73 Vincent
Yes, a translation is required.
PE2V
DL2RUM wrote: Wed 20. Nov 2019, 17:26 Yes, a translation is required.
OK, no problem!
PE2V
Hereby:
http://www.pi4lwd.nl/11engtxt.htm The Frisian Eleven Cities Contest (thanks to PA3JD)
DL1PA
Unread post by DL1PA »
What about the DARC Schwaben - Contest, see
https://www.darc.de/der-club/distrikte/ ... n-contest/
A support by the Contest -Module would be Great.
73 de DL1PA
NN7M
CQ DX 160m contests was last weekend. It could use a W side like some other contests do. As a US station, my exchange is 5NN <State>
Since I’m in Washington state, my exchange is 5NN WA
This weekend, the contest window auto filled ‘3’
Ryan NN7M
I can't conform that. Please provide a screen shot.
NN7M
CQ website says the rules have changed, so perhaps this is a new requirement.
US states provide two letter state abbreviation, Canadian provinces provide two letter provide province abbreviation.
DX countries provide CQ zone.
https://www.cq160.com/rules.htm
Here's what my contest screen looked like for the January test. Note that I manually entered WA in the 'sent' field before saving the qso.
