Sometimes I read the feature request to allow RUMtrol an import of *csv files, created by a spreadsheet. I'm not quite sure, if there is any standard or everybody uses an own format. What format do you use? I could add an import function into the program, but only one. I don't like to adapt the software to individuals.
I've got an example file from Dave, WB7G:
- Code: Select all
Memory number (1-99 or 1A, 1B, etc.)
Channel name (0 to 9 ASCII chars) (Would = "BLANK")
Frequency in Khz (xxxxxx.xxx or NULL string)
Mode (AM,FM,LSB etc.or NULL string)
Filter (1,2,3 or NULL string)
RX SUB Freq (or off or NULL string)
TX SUB Freq (or off or NULL string)
DTCS type (NN,NR,RN,RR or NULL string)
DTCS code (023 to 754 or NULL string)
DUPLEX (DUP+ or DUP- or NULL string)
SCAN (ON or OFF or Null string)
SPLIT (ON or OFF or Null string)
1,"W6PW SF",145350,"FM",1,"OFF",114.8,,,"DUP-","ON","OFF"
2,"KF6CLH",145410,"FM",1,,"OFF","NR",51,"DUP-","ON","OFF"
3,"SR",145470,"FM",1,,88.5,,,"DUP-","OFF","OFF"
4,"Oakland",145490,"FM",1,,131.8,,,"DUP-","OFF","OFF"
5,"I3545",146115,"FM",1,,88.5,,,"DUP-","OFF","OFF"
6,"Mdiablo",146205,"FM",1,,100,,,"DUP-","OFF","OFF"
Any other suggestions?
