Hallo Tom,
eben geladen und getestet. Fehler ist immer noch da.
Der Ball erscheint und das Programm friert ein, wenn ich in den Eigenschaften oder Contesteigenschaften irgendwohin klicke.
Siehe hier:
73 de Andy, DL1AKP
RUMlogNG version 4.0
Re: RUMlogNG version 4.0
OM Andy DL1AKP / AB7VT
QTH Mitteldeutschland
2015 iMac 27" 5K
macOS current version
2015 iMac 27" 5K
I found a bug with V 4.0.2 and Mojave. When I select "Load LOTW users" under the "Online" menu item, Rumlog reports a message in the attached screen capture. (I have Rumlog installed in ~/Applications, and not in /Applications)
Seems not to be a bug. Looks to me like a server side error.
Yes I can confirm this. It is not a bug in RumlogNG. Thanks for the hint that i could follow up on. I was getting traffic from the dx cluster, but a proxy had apparently interfered with the LOTW user query.
Spinning beachball after opening the Preferences
In the last two days I started RL and opened the Preferences ca. 100 times without any problems. I know, there is still a problem, so I need your further assistance.
Pse try this version: http://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip (Build 275)
When my theory is correct, you should be able now to open the Preferences without a hang. Go to the Phone tab, there is a new button in the R/H lower corner: "Set Audio" This will update your volume and sound card settings. Press this button. Any hangs now? Try how often you can.
Thanks for your help.
Unfortunately program crashes each time I press Set Audio button.
Norm
Norm
Please log out from the system, or better reboot, and try again please.YL5T wrote:Unfortunately program crashes each time I press Set Audio button.
Norm
Disregard my last post, try this please: http://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip (Build 276)
The latest TEST version is perfect.
Thanks!
Norm
Thanks!
Norm
RUMlogNG version 4.0.4
RUMlogNG 4.0.4 is awaiting you in the Mac App Store: https://itunes.apple.com/app/rumlogng/id964454561?mt=12 or for download from here: http://dl2rum.de/RUMlogNG/RUMlogNG.zip
- Fix: Crash when using the IC-7610/IC-7300 Control Panel - Tnx Terry, M0CLH & John, N1JM
- New: WinKeyer - Control for QSK compensation added
- New: Reduced frequency for repeated spoken dx-spots - Preferences-->DX Alarm-->Spoken DX Spots
- New: A callsign in WSJT-X will be 'de-colorised' after saving a QSO with this station
