RumLogNG Crashes soon after opening
Re: RumLogNG Crashes soon after opening
N1JM
Unread post by N1JM »
Okay It was not set but now I have set it to Auto Discovery.I did notice from time to time I would have to reset the IC-7610 comport but it never caused a crash before. Now that it is set I will see what happens.
Thanks, John N1JM
N1JM
Just went into preferences and then closed preferences and crash again.
crash again.rtf
(79.13 KiB) Downloaded 154 times
crash again.rtf
N1JM
The crashing seems to be associated with the IC-7610. I have taken the IC-7610 out of RomlogNG and it hasn't crashed yet. I have only the K3s now.
73, John N1JM
N1JM
Well program has not crashed yet but will hang when going into preferences and this time when changing to a different tab. Have to force quit the program.
73, John N1JM
I have seen the hang now by myself. :-( It has something to do with the installed/connected sound cards. Even if you haven't configured any. I made few changes and haven't it seen it again. But I was not so much affected like you. There is at least one other user affected with the TRX problem. This I have never seen and I have still no idea.
Pse check this version for hangs: http://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip
N1JM
I just tried the new version from he Mac app store and the program crashed when exiting preferences.
73, John N1JM
Crash Report?
N1JM
Here it is.
rlcrash101218.rtf
(79.1 KiB) Downloaded 144 times
rlcrash101218.rtf
