Manual log entry from a SOTA activation initiated a surprise reversal from DD/MM/YY to MM/DD/YY when I upgraded from Rumlog to RUMlogNG. Though Preferences clearly documents the change, I'm surprised the DD come first option is no longer available, or is it?
Larry, W6UB
Date Format
Re: Date Format
As far as I know SOTA uses a special format for log upload. If I could find more information, I would support it directly.
You can (temporally) change the date format to DD/MM/YYYY in your System Preferences. Restart RUMlog and the CSV file will have this format. (It has to match your selected format - Short, Mid or Long)
Re: Date Format
Tom, here is the URL for SOTA logging format: http://www.sotadata.org.uk/ChaserCSVInfo.htm
Thanks for your effort,
Larry, W6UB
Larry, W6UB
