I have noticed that it does not work on 60m (5MHz), will this be sorted anytime?
James
60m 5MHz Support
Re: 60m 5MHz Support
No Frequency being displayed in logbook.
After logging? Some more information would be helpful to understand the problem.
Sorry...
I have 2 Macs here that I have been given to see if they would be useful to loan out for DXpeditions, both are iMac 28" 5K 4GHz units, I have one with a MicroKeyer II and another with a DigiMaster pro 3 interface, the latter is causing issues in another thread so I will stick with the MKII.
Everything works fine out of the box so to speak except when I tune into 60M, when rotating the VFO on both the Kenwood TS-570 and the Yaesu FTDX-5000 it responds OK in the application, all bands work, tuning via the cluster is OK, and everything seems OK except for when I tune to 5 MHz then the freq in the application just goes blank, when I go back to say 20m I see a frequency, then when I return to 5MHz - Nothing???
James
James
Sounds interesting. I've tested it here with the K3 and with the Kenwood CAT setting works fine. I can tune to 60m and the frequency is always shown correct-
Can anybody else here try this out please?
