I think this is the last problem I'm trying to solve as I try to migrate from RUMlog to RUMlogNG ...
In classic RUMlog, I made great use of the "additional" band maps ... In the new RUMlogNG, though, I don't see an option for displaying that. In the "additional" band map window, I could manually change bands as I needed in order to have a quick look at what was going on with the other bands. Unfortunately, I can't seem to figure out how to change the "active" band in the RUMlogNG (I'm not using any hardware interface to the transceiver yet).
Let me know if I'm just missing this, in which case I'm sorry to bring it up! (User error?)
Thanks, and 73,
Randy K7RAN
Additional band map
Re: Additional band map
Well, as an interim step until "Additional Band Map" is implemented, would there be a way for me to change the map from one band to another? It's stuck on 20 meters for me. Thanks, Tom!
Randy K7RAN
Randy K7RAN
Quick follow-up... What would be the "correct" way to change bands in the band map? Mine is stuck on 20 meters for now.
Randy K7RAN
Randy K7RAN
The currently available band map follows the transceiver only.
