I use CM with Rumped and my K3. What are others using? Is FLDGI any better?
Thanks and 73, John N1JM
What RTTY Program?
Re: What RTTY Program?
Fledgi probably has the advantage of being under constant development and covers more modes.
However, I use CCM mostly because I can have waterfalls from both my K3's VFO A and B. It's great to be able to see the DX station on one waterfall and click around in the pile-up on the second waterfall.
I suppose you could do the same thing with two instances of Fldigi running (different versions) but it would consume a lot of screen real-estate.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Thanks, Rick. CCM seems to integrate very nicely with RUmlog or Rumped. Haven't used FLDIGI hardly at all to know if it demodulates better then CCM.
73, John N1JM
73, John N1JM
I have run them both together and I don't think CCM gives up much if anything in demodulating to Fldigi.
What I have done, just to try to make sure I don't miss anything, is to run CCM with RUMlog for the FSK-D capabilities of the K3 and also run Fldigi on my other screen as a back up. Don't notice that it helps much if at all though.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
