I do not see the "undo" command ?
For example I made a mistake, I used the "LOTW ADIF out" Item, so RUMLog has created an ADIF File and AUTOMATICALLY the LOTW Flag has been modified to "S" without any Warning, I How Can I made an "undo" command ?
Perhaps a New feature ?
I Think for these "global" command it will be necessary to have one Warning windows BEFORE ?
Daniel
Undo ?
Re: Undo ?
There is no UNDO available and there are no intentions to implement this. Since your ADIF file is saved somewhere, the data are not lost. Also you can manually set the qsl status back to W.
F6FLU
- Contact:
Re: Undo ?
1) The file is created
2) A new windows will ask the user if You want to set or no the flag to "S"
I think that will be better with this 2 steps
What do You think about that ?
Daniel
So I understand that but I have about 1000 QSOs with the "S" Flag, so If there is not "Undo" command perhaps You have to implement this feature with 2 steps :DL2RUM wrote:There is no UNDO available and there are no intentions to implement this. Since your ADIF file is saved somewhere, the data are not lost. Also you can manually set the qsl status back to W.
Daniel
Re: Undo ?
Select your 1000 QSOs with 2 mouse clicks and use the Menu-->QSL-->Send agn LoTW QSL This will undo your action. It's not a problem for the LoTW server when you send some QSOs twice.
F6FLU
- Contact:
Re: Undo ?
I don't make this beacuse I don't Know where are the QSOs flagged ? and the are not consecutive ...DL2RUM wrote:Select your 1000 QSOs with 2 mouse clicks and use the Menu-->QSL-->Send agn LoTW QSL This will undo your action. It's not a problem for the LoTW server when you send some QSOs twice.
Re: Undo ?
Are you using Time Machine?
If so, revert back to the last log before you asked for the LoTW_out.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
F6FLU
- Contact:
Re: Undo ?
Hi Rick
I think that a very good idea, but one "undo" feature will be better !!
Dan
Dan
