Page 2 of 3
Re: RUMlog FAQ
Posted: Sat 3. Jan 2009, 00:41
Use the 'Save as text file' button.
- dxcc.tiff (29.16 KiB) Viewed 12430 times
Re: RUMlog FAQ
Posted: Sat 28. Mar 2009, 11:52
by K9TF
Is there a Keep Alive feature for the Packet or Telnet connection? What time is the Keep Alive feature set for? Am I able to adjust it? I would like to set my own for 3 minutes. The node I connect to drops me off cause of inactivity, I think, and need to shorten the time to see if it fixes the issue.
Is there an easier method to check this problem out or a solid node on the internet for me to connect to, to make a determination on this? I am running a packet program called Spot, connecting to K3NC cluster and I do not have this problem. I have reason to suspect that when my Mac is Idle and the hard drive shuts it self down at night, cause I have it on 24-7, Rumlog may not like that. How ever during the contest this week-end it has NOT had the problem, so I have more a reason to believe it is eather the node or the Keep Alive time setting. On some nodes 5 minutes is a bit too long, I use to set VE7CC program to 3 min and had very few issues. Most of the time it was my connection to the internet or the nodes connection.
Setting Keep-A-Live to even 4 or 4.5 minutes would be good. Could be a CPU timing issue. Some clocks on some CPU's run faster or slower must be another Windows PC compiler issue thing.
For Rumlog I use K9USA or N9JR-2 nodes on the internet using Telnet.
Jim
Re: RUMlog FAQ
Posted: Sat 28. Mar 2009, 14:17
Currently the time is fixed to one minute. Every minute RUMlog will send just a line feed. I have had never problems with disconnects. There is a lot of activity this weekend, due to the WPX. I will check it out next week.
Please give me the access data for your preferred cluster.
Re: RUMlog FAQ
Posted: Sun 29. Mar 2009, 03:21
by K9TF
Well then that rules out the program and Keep-A-Live. Must be node issues or my CPU. I will have to dwell on this and see what I need to do next. Any ideas?
Thanks. Jim
Re: RUMlog FAQ
Posted: Sun 29. Mar 2009, 03:39
What about your internet connection? Maybe it shuts down, when there is no traffic?
Re: RUMlog FAQ
Posted: Sun 29. Mar 2009, 13:11
by K9TF
That thought had occurred to me at one time. Glad you brought it up. I was wondering if I can leave some type of internet web page open on the computer that updates regularly. Do not know what kind of web page live video or what. Have your heard of any thing like this before? What was done in the past?
Jim
Re: RUMlog FAQ
Posted: Sun 29. Mar 2009, 13:21
by K9TF
Oh What do you mean by inactivity? Me not moving the mouse or key board or nothing going on at the packet node or what?
Jim
Import Error messages?
Posted: Sat 7. Nov 2009, 03:36
by n2fq
Hello.
Where does Rumlog put these error messages?
They scroll up to fast to read and there is no scrollbar
in the window to scroll to the beginning.
tnx. 73 Fernando N2FQ
Re: RUMlog FAQ
Posted: Wed 11. Nov 2009, 07:26
by DK5LP
Hi Fernando,
please be patient.
Tom works outside (VP2MUM).
Re: RUMlog FAQ
Posted: Thu 12. Nov 2009, 04:41
by n2fq
Tnx Karl. I appreciate the note and no problem waiting.
73 Fernando N2FQ/6
