dxcc.rsd
dxcc.rsd
Unread postby SV2AEG » Fri 2. Feb 2018, 19:10
HELLO EVERY ONE
At last days I delete old Rumlog and I downloads the version 5.3.13. At first I open a new log.rsd . Second I open the RUMlog.app. and I see the message " I can't connect the DXCC.rsd base". I try again and again but I have the same message always.
What is the wrong with me?
Thank you for the help. 73 Kostas
SV2AEG
Re: dxcc.rsd
Unread postby DL2RUM » Fri 2. Feb 2018, 19:41
The file “DXCC.rsd” must be located in the same folder.
Re: dxcc.rsd
Unread postby SV2AEG » Fri 2. Feb 2018, 20:18
Yes the file DXCC.rsd is always in the same folder with RUMlog.app,Cluster.rsd, IOTA.rsd, e.t.c
but at the program begin I always have " I can't connect the DXCC.rsd base" and at the Telnet DX Cluster have Unknown country!!
SV2AEG
Re: dxcc.rsd
Unread postby DL2RUM » Fri 2. Feb 2018, 20:28
Then the file may be damaged or corrupted.
Re: dxcc.rsd
Unread postby SV2AEG » Sun 4. Feb 2018, 11:24
Thank you Tom for response
but today I try again new installation and I have the same problem" I can't connect the DXCC.rsd base".I also check K7PT database and always have:
"Can't connect to UCSDB database". What the wrong? My iMac has "macOS High Sierra version 10.13.2". 73!
SV2AEG
Re: dxcc.rsd
Unread postby DL2RUM » Sun 4. Feb 2018, 11:27
Show me the contents of the folder where RUMlog is located.
Re: dxcc.rsd
Unread postby SV2AEG » Sun 4. Feb 2018, 12:29
SV2AEG
Re: dxcc.rsd
Unread postby DL2RUM » Sun 4. Feb 2018, 13:06
Looks good. No idea. You should update to NG: https://itunes.apple.com/app/rumlogng/id964454561?mt=12
Re: dxcc.rsd
Unread postby SV2AEG » Fri 9. Feb 2018, 17:59
Hi Tom
Finally I find the solution to my problem.First I downloading the software and I unzip it into a folder from another pc to a usb stick.After I transfer it to my iMac where it works very well. Maybe the error was to my iMac!
Thank you very much, and all the best. 73 Kostas
SV2AEG
Return to RUMlog
Who is online
Users browsing this forum: No registered users and 4 guests
