How ESM works? (Enter sends messages)
Unread postby DL2RUM » Fri 27. May 2011, 16:30
I've tried to create few flowcharts. Maybe it is helpful. I added also the graphics as a pdf file.
ESM-Contest-S&P.pdf
(71.27 KiB) Downloaded 376 times
ESM-DXped-Running.pdf
(104.18 KiB) Downloaded 328 times
ESM-Contest-Running.pdf
(121.54 KiB) Downloaded 340 times
Re: How works ESM? (Enter sends messages)
Unread postby ky4f » Thu 8. Dec 2011, 15:33
Great charts Tom. Thanks!
73, Doug
KY4F
ky4f
Unread postby K6LE » Sat 28. Jan 2012, 22:21
I must have missed this in the instructions.
If I am in S&P mode using ESM everything goes fine unless the other station asks "NR?". By that time ESM has already logged the contact and the number has been incremented.
If I hit F6 again it will send the next number.
Is there a way to send the original number without going to Keyboard mode?
TIA
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Unread postby DL2RUM » Sat 28. Jan 2012, 23:04
As far as I know someone reported this before. It seems to be my fault. Stay tuned ....
Return to RUMped
Who is online
