First Contest using RUMped!
G4FSU
Unread post by G4FSU »
I used RUMped for the first time in a contest last night, the RSGB 80M CC.
It worked perfectly and I'm very impressed with the layout and control of the K3. I particularly like the ESM implementation which I used both in run and S&P modes & it seemed to always be set to send the correct message, even after some messed up or non-standard exchanges. I like being able to space or tab between the fields and have the logger recognise what the correct message to be sent is because of the active field. I think this is the best implementation I've seen of ESM. Also the ability to send CW using the K3 internal keyer, which allows control of the speed directly from the front panel, is a nice implementation not found on other loggers.
Keep up the good work!
73 Ian G4FSU
