/MM /00
IV3TMM
/MM /00
Unread post by IV3TMM »
Just tried to input a callsign with /MM or /00 ... now it works.
QSO doesn' t count for DXCC, right, well done.
But when you export this "Unknown DXCC" you miss to export also the <DXCC> key. Please insert it with number 0 (zero).
Change also the fields DXCC, Cnt, CQ and ITU to blank, empty in the qsos database. That' s a good solution. Export them with adif keys equal to "" void, empty.
Ciao de Francesco
IV3TMM
IV3TMM
Re: /MM /00
Any news ? Is that mod inserted on 2.14 version ?
Ciao de Francesco
IV3TMM
IV3TMM
Re: /MM /00
Hello, why don' t you have inserted the mod requested in the last two versions ?
I think is not correct to export a qso without the ADIF DXCC key number even if is "0" zero.
Please upgrade it.
TY.
Ciao de Francesco
IV3TMM
IV3TMM
Re: /MM /00
Hi Tom, now you can upgrade your software because there is a DXCC Key for the NO ENTITY and the number is 0 (zero).
Look Adif 3.05 specifications under:
III.B.7 DXCC Entity Code Enumeration
Please update, export and import the DXCC KEY = 0
TY ciao Francesco IV3TMM.
Ciao de Francesco
IV3TMM
Re: /MM /00
I have introduced this in version 3.3 from February 2017.
IV3TMM
Re: /MM /00
Checked all is OK, but now when you import ADIF file, the Key <comment: > import the text to import + one more character "-"
Please delete the last character.
Ciao.
Ciao de Francesco
IV3TMM
Re: /MM /00
Show me the ADIF File.
IV3TMM
Re: /MM /00
ADIF Export from RumLogNG by DL2RUM
For further info visit: http://www.dl2rum.de
<ADIF_VER:5>3.0.5
<CREATED_TIMESTAMP:15>20170802 202517
<PROGRAMID:8>RUMlogNG
<PROGRAMVERSION:5>3.6.2
<EOH>
<call:8>EA6IB/00 <qso_date:8>19920706 <time_on:6>161600 <time_off:6>161900 <band:3>20m <freq:9>14.096000 <mode:3>PKT <rst_sent:3>599 <app_rumlog_qsl:1>S <qsl_rcvd:1>N <qsl_sent:1>Y <dxcc:1>0 <name:15>PIRATA NO EA3KU <qth:19>QSL VIA EA6PZ EA6FB <comment:7>NO DXCC <qsl_via:6>EA6URA <gridsquare:6>JM08RV <tx_pwr:3>100 <app_rumlog_power:3>100 <eqsl_qsl_rcvd:1>N <eqsl_qsl_sent:1>Y <lotw_qsl_rcvd:1>N <lotw_qsl_sent:1>N <pfx:3>EA0 <clublog_qso_upload_status:1>Y <operator:6>IV3TMM <my_gridsquare:6>JN66KM <app_rumlog_colorcode:1>7 <eor>
Ciao de Francesco
IV3TMM
Re: /MM /00
Where sis the problem?
IV3TMM
Re: /MM /00
When you import this key:
<comment:7>NO DXCC
you will find in the Note field of RumLogNG:
NO DXCC-
Character minus "-" is not in the adif file.
You understand ?
Ciao.
Ciao de Francesco
IV3TMM
