RUMlogNG for Yaesu FT DX 1200?
Unread postby DougY » Wed 24. Oct 2018, 23:56
I have a Yaesu FT DX1200 Transceiver, and have RUMlogNG installed on my iMac. I have, in the past, been using this program for logging my Icom 746Pro QSO's with no problems.
I bought a USB 2.0 RS 232DB 9 PIn Female Serial Cable, connected it from my Yaesu Transceiver to my iMac. However, it doesn't seem to be talking to my RUMlogNG software. Anyone have suggestions to fix this issue?
DougY
Re: RUMlogNG for Yaesu FT DX 1200?
Unread postby DL2RUM » Fri 26. Oct 2018, 08:20
It's not required to post a problem again and again.
See to the logging fields in the logging window. In which colours are kHz and Mode written?
Show us your TRX settings.
Unread postby DougY » Sun 28. Oct 2018, 15:52
This looks good, when your try is configured for 4800 baud and RTS/CTS.
DougY
Unread postby DougY » Sun 28. Oct 2018, 15:58
DougY
Unread postby DougY » Sun 28. Oct 2018, 16:13
DL2RUM wrote:It's not required to post a problem again and again.
http://dl2rum.de/forum/download/file.php?mode=view&id=680&sid=11ab15eab3420f927320253f78514110
DougY
Unread postby DL2RUM » Mon 29. Oct 2018, 18:19
Do you use a microKEYER II or DigiKEYER II? The port name doesn't look familiar.
Unread postby DougY » Tue 30. Oct 2018, 02:17
DL2RUM wrote:Do you use a microKEYER II or DigiKEYER II? The port name doesn't look familiar.
I have NO idea what those are.... :shock:
That was the only Serial Port option on the Port drop down screen.
DougY
Unread postby DL2RUM » Tue 30. Oct 2018, 08:28
Then reset your selection to Do not use! Only the settings under the TRX tab are required.
Unread postby DougY » Tue 30. Oct 2018, 16:52
DL2RUM wrote:Then reset your selection to Do not use! Only the settings under the TRX tab are required.
Changed to "Not Used", still no communication between my Transceiver and RUMlogNG. :roll:
DougY
Unread postby DL2RUM » Tue 30. Oct 2018, 22:31
Check again the text colour for the kHz and Mode label. In your last screen shot it is shown in blue, it should be red or green when you have configured CAT.
Next
Return to RUMlogNG
Who is online
Users browsing this forum: No registered users and 3 guests
cron
