RUMlogNG version 4.0
Posted: Tue 25. Sep 2018, 15:52
RUMlogNG 4 is available here:
http://dl2rum.de/RUMlogNG/RUMlogNG.zip
RUMlog 4.0 and newer requires macOS 10.13 (High Sierra)
What's new?
The IC-7610 'Auto Discovery' function doesn't work under macOS 10.13 High Sierra!
What's new?
- Changed: Alle drawer type panels are now "normal" windows (HamQTH/qrz.com, RTTY, multiplier help) due to missing support in upcoming macOS versions
- Changed: Manual saving of QSOs from WSJT-X
- Changed: macOS 10.13 (High Sierra) or newer required
- Deleted: Growl support removed, due to missing 64bit supoort
- Deleted: Import of RUMlog Classic logbook files
- New: Support for Dymo Labelwriter 90mm x 38mm
- New: Support for label format Avery 3477
- New: Support "Dark Mode" in Mojave
- New: DXCC Entity table shows headings and directions
- New: Data take over from the HamQTH/qrz.com result table to the **Edit QSO** entry mask
- New: Touchbar support in the IC-7610 control panel
- New: In WSJT-X saved QSOs can be saved in the Contest log useful for Dx-Peds
- New: Filter options in the contest DX-Spot window (FT-8 frequencies are fixed)
- New: FT8 mode recognition for DX-Cluster spots (FT-8 frequencies are fixed
- New: New ADIF tags <TEN_TEN> and <FISTS> for user definable logging fields
- New: Optional use of macOS location services whenever the own grid square needs go be entered
- New: Scope for IC-7610/IC-7300 shows more control options
- New: Contest Scoreboards
- New: Level slider in theIC-7300 Control Panel
- New: DMC RTTY Contest
- New: Russian translation started - Tnx Vladimir, R2ADU
